Activity Forums Adobe Premiere Pro D800 and prores in CS5
  • D800 and prores in CS5
    Posted by Jack Rusak on July 13, 2012 at 6:13 pm
    Also asked this over on the Dslr forum, but this might be the better venue….Just got the D800 and find I need an external video recorder to get ‘broadcast quality” but the one I’m looking at encodes it to 10-bit, 4:2:2 Apple ProRes.
    Would I have any problems editing that on a PC running PPro CS5? I assume I would have to convert it to another format..
    Bo Skelmose replied 14 years, 2 months ago 3 Members · 4 Replies
  • Jeff Pulera
    July 13, 2012 at 8:05 pm
    Hi Jack,
    Premiere will handle ProRes just fine, except there was a bug in CS5 and maybe into CS5.5 also (before the 5.0.3 patch) which would show ProRes files with 4-channel audio as a non-supported format when you try to import them. Note that clips with 2-channel audio worked well, so just make sure that is how you record them.
    Are you looking at the Atomos recorders?
    Jeff Pulera
    Safe Harbor Computers
  • Jack Rusak
    July 13, 2012 at 9:11 pm
    Yep, looks exciting. I assume the D800 would automatically record in two channel?
  • Jeff Pulera
    July 13, 2012 at 9:19 pm
    Hi Jack,
    You will get stereo audio from the camera in the HDMI stream. The Ninja can be set to record 2-channel (stereo) audio from HDMI or the analog mini jack input, or 4-channel audio when specifying BOTH inputs. Just set up in the Ninja menu. With CS5, you would want just the two channels because Premiere won’t accept the 4-channel clips, so do a test before committing to an actual event recording and make sure the workflow is correct.
    You can review the Ninja User Guide here – https://www.atomos.com/ninja/manual/ninja-user_manual.pdf
    Note we expect the new Ninja 2 to be shipping in the next week or so, adds larger screen and an HDMI output.
    Jeff Pulera
  • Bo Skelmose
    July 14, 2012 at 7:49 pm
    Hi
    I have not tested but read elsewhere that the Nikon D800 do not output audio in the HDMI stream…..
    CS5 do not work with AVID DNxHD or the AVID Quicktime format from the Black Magic Hyperdeck Shuttle 2.
