Activity › Forums › Broadcasting › D5 HD Reference Input
  • D5 HD Reference Input
    Posted by Corbin Daily on February 14, 2010 at 3:21 am
    Does anyone know how to change the input reference signal on a Panasonic AJ-HD3700B?
    Trying to switch the deck to Tri-sync reference from SD ref…
    I’ve been through the many manual updates and cannot find anything…
    Please help…Thanks.
    Chad Brewer replied 16 years, 7 months ago 3 Members · 3 Replies
  • Mark Spano
    February 16, 2010 at 6:28 pm
    IIRC, it should be in the Home>Setup page. Right in the middle of the screen is your choices: Auto, Input, SD Ref, HD Ref. Pressing the middle button of the cursor key should give you the flashing selector, move it over to what you want (SD Ref) and then press the middle button again. I’m not 100% on this, but pretty sure.
  • Corbin Daily
    February 16, 2010 at 6:38 pm
    Thanks for the help. We are using the D5 deck in 720 mode which will only take a SD reference not Tri-sync, which is why we couldn’t figure out how to make it switch. A bit confusing, but it was in the manual. If the deck is in 1080 it will accept Tri-sync as reference. Thanks again.
    Corbin
  • Chad Brewer
    February 17, 2010 at 1:59 am
    Isn’t that VTR so totally awesome!!!
    https://forums.creativecow.net/readpost/21/859664
    Chad Brewer
    Senior Tape Operator/Engineer
    TeleVersions
