Activity Forums DSLR Video D3s rolling shutter – stabilization
  • D3s rolling shutter – stabilization
    Posted by Kyle Woodworth on May 10, 2010 at 6:42 pm
    I know now that it was a bad idea, but I took some aerial footage with a Nikon D3s. I need to stabilize the aerial footage, but due to the rolling shutter, I get the jello effect. So here is my workflow so far.
    I’ve taken the AVI footage from the camera into After Effects and applied The Foundry’s “Rolling Shutter” plug-in. Then I export a lossless Quicktime movie from that. Bring it into Final Cut Pro, where I apply Lock & Load’s stabilization software… and I still have the problem.
    I’m pretty sure that I’m not calculating the distortion correctly in the “Rolling Shutter” plug-in step, but I can’t find the correct settings for a D3s anywhere. The test footage I took to try my own calibration doesn’t seem to be effective.
    So I guess I’m asking for anyone who either knows the right rolling shutter setting for a D3s, or a proper calibration method, or any other thing I could be doing wrong. Thanks for the help!
    Colin Andrews replied 16 years ago 2 Members · 1 Reply
  • Colin Andrews
    July 16, 2010 at 10:29 pm
    Hi Kyle,
    I just came across your post of May 10 regarding fixing your aerial footage with the Foundry’s Rolling Shutter plug-in. Did you ever get anywhere with this ? I have exactly the same problem with footage I shot from a microlight on a Sony with a CMOS chip. They don’t give much guidance with the plugin.
    I’m trying out the demo & it seems to be doing some good – although it’s very hard to tell with the overlayed grid and black bar over the top third of the image!
    Any tips?
    Colin
