Activity Forums Panasonic Cameras “Cylinder Lock”
  • “Cylinder Lock”
    Posted by Jim Lawrence on November 16, 2006 at 5:43 pm
    This cropped up on the AGX100p: “Auto Off Cylinder Lock”. I’m pretty sure that’s a problem with the tape transport. Is there any easy way to fix this? (There’s no repair facility anywhere near us).
    Icemanbrad replied 19 years, 7 months ago 4 Members · 3 Replies
  • Noah Kadner
    November 19, 2006 at 7:24 pm
    It indicates a fault in the tape transport system. This can happen if the camera suffers an impact i.e. is dropped. Sometimes it develops on its own too. Most likely it needs to be serviced.
    -Noah
    Need help with DVX100, FCP and 24p editing?
    Visit http://www.callboxlive.com for an all-new training DVD from Noah!
  • Tim Scarpino
    November 20, 2006 at 1:47 pm
    I once had this warning happen when I tried to eject a tape with a near-dead battery. When I changed the battery, I still got the warning.
    On the DVX100-A there’s a “reset” button near the audio input selects inside the LCD compartment. I followed the procedure in the DVX manual and pushed the reset button with the end of a paper clip.
    If you haven’t caused some mechanical issue with the camera by, as Noah says, dropping it, you might try this.
    Good Luck,
    Tim Scarpino
  • Icemanbrad
    February 6, 2007 at 11:41 pm
    About how much does having the “auto off cylinder lock” error fixed? thanks, Brad
