Activity › Forums › Adobe After Effects › Cylinder Creator Lite… can’t get the settings right.
  • Cylinder Creator Lite… can’t get the settings right.
    Posted by Matt Sonberg on June 20, 2005 at 2:22 pm
    I’m just trying to create the walls of a 3D hub/cylinder. I want it to look as round as possible (don’t want it to have any angles along the wall). I tried using lots of different settings, but I can’t get it to work the way I want it to. I want it about 400 pixels tall and with a radius of about 3 or 4 hundred. I was just using a solid, but I can’t figure out how to set everything up to get the result I’m looking for. Can anyone help?
    Filip Vandueren replied 21 years, 3 months ago 2 Members · 1 Reply
  • Filip Vandueren
    June 20, 2005 at 11:02 pm
    Using a 3d assistant will always give you a more ‘blocky’ result.
    if you have 6.5 pro, is CC cilinder an option ?
    You can but your camera inside of it.
