Activity › Forums › Adobe After Effects › Cycore Light Sweep Effect Slow
  • Cycore Light Sweep Effect Slow
    Posted by Ziad Chatila on July 21, 2008 at 4:54 pm
    I am using CS3 and when I apply the cycore light sweep effect to simple text, the effect playbacks too slowly. How do i speed up this effect?
    I dont see any options within the effect itself. I just want the light beam to move across my text faster.
    thank you.
    Chris Wright replied 18 years, 2 months ago 3 Members · 3 Replies
  • David Bogie
    July 21, 2008 at 6:17 pm
    You must keyframe the position of the light source crosshair.
    bogiesan
  • Chris Wright
    July 21, 2008 at 6:30 pm
    although there is like a hundred ways to do this, just push the end and beginning keyframes of the animated light movement closer together. That will force them to change a large path over less time, hence a speed increase.
  • Chris Wright
    July 21, 2008 at 6:31 pm
    although there is like a hundred ways to do this, just push the end keyframe of the animated light movement closer to the start keyframe. That will force them to change a large path over less time, hence a speed increase.
