Activity Forums DaVinci Resolve Cyclon PCI epander with quadro 4000 problem
  • Cyclon PCI epander with quadro 4000 problem
    Posted by Thibault Carterot on May 1, 2011 at 1:12 pm
    I,
    I’ve got a pci cyclon expander with 3 quadro 4000 and many problems
    I wanted the users to know what I experienced :
    When I use cyclon pci expander + quadro 4000 :
    – the pci config in apple menu cannot display PCI config (it’s says error something…)
    – dongle resolve has problem at startup (like if there was no dongle, have to try 10 times to load the soft, and after, no problem in it)
    – red rocket in cyclon doesn’t work in red cine
    although
    – red rocket works in resolve
    – resolve detect the 3 GPU of the 3 quadro 4000
    when I replace the quadro 4000 by GTX 285 in the same expander unit, no more problem…
    Conclusion : quadro 4000 + Cyclon PCI expander sucks…
    Config : Mac Pro 2010, 12×2,4Ghz, 32Go Ram, 3xFX4000,GT120, Decklink 3D+, RED Rocket, system on Crucial SSD 250, RAID FC 8gb Lacie 24To, CYCLONE PCI expander, Resolve 7.1
    Michael Kelly replied 15 years, 4 months ago 5 Members · 16 Replies
  • 16 Replies
  • Thibaut Petillon
    May 2, 2011 at 8:46 am
    Hi
    We run one Q4000 + GTX285 + RedRocket in a Cyclon pci expander without any problems.
    RedRocket works fine in RedCine and in Resolve.
    Never tried installing more Q4000 for the moment…
    Thibaut
    Colourist at Les Machineurs – Paris, France
  • Thibault Carterot
    May 2, 2011 at 10:48 am
    That’s stange,
    Are you able to see the PCI config in apple menu ?
  • Thibaut Petillon
    May 2, 2011 at 2:26 pm
    I’m able to see the pci infos when I click on “about this mac” and then “more infos” then I have access to all the details about PCI cards…
    Thibaut
  • Thibault Carterot
    May 2, 2011 at 2:29 pm
    Could you tell me the slot config you have in your mac ?
  • Thibaut Petillon
    May 2, 2011 at 2:59 pm
    slot 1 : pci expander
    slot 2 : GT 120
    slot 3 : decklink
    slot 4 : storage
    Hope that helps
    Thibaut
  • Thibault Carterot
    May 2, 2011 at 3:23 pm
    very interesting indeed.
    I followed Davinci recommendation and put the Pci expander in slot 2 but I guess that should solve my problem !
    I’ll try asap and let you know
  • Thibaut Petillon
    May 2, 2011 at 4:21 pm
    the “Thibaut” got to help each others 😉
    Thibaut
  • Thibault Carterot
    May 2, 2011 at 4:22 pm
    Well, in fact, it didn’t change anything. When I put a quadro 4000 it doesn’t show the pci details anymore…
    The last thing I could check is that I use a SSD drive for system but I doubt it creates such a problem…
  • Joseph Owens
    May 2, 2011 at 5:20 pm
    [thibault carterot] “When I put a quadro 4000 it doesn’t show the pci details anymore…”
    This may be a really dumb question, but you DO have Quadro FX4000 “For MAC”… right? A PC version won’t work.
    jPo
    You mean “Old Ben”? Ben Kenobi?
  • Thibault Carterot
    May 2, 2011 at 5:28 pm
    Yes of course, they are mac version. And by the way, when I put them in the mac pro, it works perfect.
    It works also with FX4800 in the expander. The only card that seems to have a problem with my expander is the 4000.
    For the record, I tried 2 different expander and 2 different mac pro.
    I getting crazy…
