Activity › Forums › Adobe After Effects › Cyclist at SUNSET
Cyclist at SUNSET
Posted by Kalyan Tagore on May 14, 2013 at 9:52 amHey friends,
I am making a short documentary about a Cyclist. The END FRAME of the video should be something like this…
” Cyclist approaching towards the Horizon (or SUNSET) ”But I dont have a perfect location like this to shoot..
What is the best way to achieve this shot by ‘Compositing’??Plz suggest me your views
Kalyan Tagore replied 13 years, 3 months ago 3 Members · 6 Replies -
Tudor “ted” jelescu
May 14, 2013 at 10:55 amShoot the biker on stands in a chroma studio with adequate lighting and a long lens (you’ll need a chroma setup that will allow you to setup the camera close to the ground at a significant distance from the subject). Shoot some moving plant elements and the sun with a long lens as well. Then you can composite the shot adding maybe some heat distortion.
Tudor “Ted” Jelescu
Senior VFX Artist -
Kalyan Tagore
May 14, 2013 at 11:12 amBut Ted, this is a low budget film, I cant afford that kind a setup.
Now what is the alternative? -
Tudor “ted” jelescu
May 14, 2013 at 11:21 amThen best would be to find the right location.
If that’s not possible:
Find a good location for the shot- road on a hill- where you can set the camera low and far to get the same look as in your reference shot, preferably with just blue sky as background. Shoot a nice sunset with the long lens as well. Comp the sun in the first shot and alter the color/levels to match the look you’re after.Tudor “Ted” Jelescu
Senior VFX Artist -
Kalyan Tagore
May 14, 2013 at 11:34 amThanx Ted.. this sounds cool. I guess I can make this look good.
Chris Brett
May 14, 2013 at 11:42 amHi
—- for low budget version suggest…1 ) shoot cyclist on location as per ref against a clear sky ( as much as possible ) so that the cyclist is essentially in silhouette.
2 ) luma key cyclist and landscape over a still frame of sunset.
3 ) add an animating lens flare to sell the shot.
4 ) if you have any footage of birds that will key maybe add a few as silhouettes as well……..
…………… wont win any prizes but if done thoughtfully with a few tweaks can look very effective.
————– all the best ———chris —
Kalyan Tagore
May 14, 2013 at 3:47 pmThx so much guys!… for the inputs. I’ll try my best, within the given time.
