Activity Forums Adobe After Effects Expressions Cyclist animation – use expression to slave a DUIK rigged character to a motion path of pedaling
  • Cyclist animation – use expression to slave a DUIK rigged character to a motion path of pedaling
    Posted by Christine Edwards on March 6, 2017 at 2:09 am
    I’m trying to animate a DUIK rigged stick figure on a bike pedaling. My left and right foot controllers are slaved to a Null layer with a pasted ellipse motion path right where the chain rings would be. So far the animation looks good, the legs pedal around in a circle, but the legs are in unison. Is there an expression I can use to stagger the two legs? The comp is two seconds long, that I plan to loop in other comps.
    I am not familiar with expression other than wiggle.
    -Christy
    Macbook 2.7 Ghz Intel Core i7 / 8GB 1600MHz DDR3 / NVIDIA GeForce GT650M 1024 MB graphics / Apple Thunderbolt Display /
    OS X 10.8.4
    Victor Mayorga replied 9 years, 6 months ago 2 Members · 1 Reply
  • Victor Mayorga
    March 8, 2017 at 4:53 am
    I have tried something like this before with flapping objects and I did not want them to flap exactly at the same time. What I did was I just moved one set of key frames over a few frames so that they did not land on the same spots at the exact time. Now they would still MOVE at the same rate/speed but one would either be more ahead or behind the other.
    If you want them to randomly change rate/speed, so that sometimes the left is faster than the right or the right faster than left at times that might be a more tricky to do IMO.
    I assume since your using a circle path to have the Nulls rotate around there should be a few points in the path. Maybe turning a few keyframes into easy ease? ease in or maybe out so that the rate is slower/faster on some parts of the circle vs others?
    Hope this helps.
    Visual Effects & Motion Graphics Artist
