Activity › Forums › Lighting Design › CYC Wall Ceiling Height Constraints
  • CYC Wall Ceiling Height Constraints
    Posted by Derreck Tomas on September 7, 2015 at 12:34 am
    I could use some feedback on the probability of constructing a cyc wall inside my house. I can open up the ceiling in one room into the attic to get the height of 14′ plus. One concern is a header that drops the ceiling height to 8′ at about 13′ in the length; the room ceiling height is 9′. The Cyc wall I want to construct would be 8′ in width and approximately 12′ in height I have included a drawing of the room as a reference.
    Mark Suszko replied 11 years ago 2 Members · 3 Replies
  • Mark Suszko
    September 7, 2015 at 5:05 am
    Well, what are you planning to shoot? And what about the floor?
  • Derreck Tomas
    September 7, 2015 at 5:19 am
    I want to shoot full-length, single portraits. The floor I am open, current ideas are masonite or paint and puddy the existing hardwood to look seamless.
  • Mark Suszko
    September 7, 2015 at 6:52 pm
    Easy cyc for your needs:
    Buy a cheap roll of vinyl sheet flooring: any kind, any color, as long as it has a flat “felt” back side. That side, the part that gets glued down to a floor, you will paint. You trap one end between 2×4 boards with screws, grid-hang, hook, or hang or clamp that to the top of the wall, let it unroll down and make a natural catenary curve. Pre-prime this felt side with Kilz brand white latex water-based primer (NOT OIL BASED!)
    Then you can paint white,gray, or chroma green. You get wall and floor and limbo in one go. Save some paint for a couple props like a stool/box and a door frame. And some dowel rods.
