Cutting/Finishing MC8 Project on MC5…
I am taking over a project that was started in Media Composer 8 and am wondering if there are any issues that will come up if I use MC5.5.5 to continue with it.
I have copied all the bins into a newly made project in MC5 and everything seems fine except for one thing. All the sequences have a blank effect icon on the video clips. I assumed it was for color correction but have been told there was no color correction done in the Avid. The color of the shots in the sequences matches the color of the original clips that were cut in. I can edit the sequence as far as trimming out the shots with no apparent issues.
If I cut in a new piece from the dailies clip it does not have the effect icon on it. If I cut the entire sequence into a new edit the icons are still there. Does this have to do with the new Color Management in later versions? Based on a QT output made in MC8, the color I’m seeing in the Avid is washed out so perhaps there’s a LUT that’s not applied in MC5 because it doesn’t have the Color Management? If so, why does it not show up if I’m cutting in dailies now in MC5 but the sequences from MC8 have the effect icon on them? Wouldn’t that be something that’s in the clips not the sequence?
Is there any reason I should be concerned about this?
Also, just for fun I tried opening the MC8 project in MC5.5.5 and it opened fine and I could open bins and see the edit. I’m going to use the project I made in MC5 with the bins copied into it, but is the project supposed to be backwards compatible like that?
