Activity Forums Maxon Cinema 4D Cutting up a logo and shattering it.
  • Cutting up a logo and shattering it.
    Posted by Isaac Wolfram on August 12, 2010 at 9:57 pm
    Originally I cut up a piece of glass and put an alpha logo texture on it, and got a pretty good shatter.
    But now I have to do a similar effect to the logo. After I extrude the logo, make it editable, and do a few other things just to make it one object I’m not getting the same explosion effect.
    Here is my problem with messing with explode segments and disconnect, I get a bunch of caps and rounded edges exploding everywhere.
    This is my render is looking when I use Explosion FX, I’m getting way to many pieces, I just want big pieces for key points, and a bunch of little pieces where I cut it up.
    Who doesn’t fall, cannot rise.
    Jiggy Gaton replied 16 years ago 3 Members · 3 Replies
  • Jiggy Gaton
    August 14, 2010 at 6:05 am
    There is a tut out there on doing this shattering logo, also used in the TV show Fringe, and I went thru the tut once (no longer have the file) and there as a long discussion posted on https://www.photoshopcafe.com about the tut as well. However, that site is down now, and the search function never really works right anyway. But the truth is out there!
    jigs
    Phoenix Studios Nepal: A small A/V Production House in Kathmandu.
  • Luisa Rodriguez
    August 15, 2010 at 4:32 pm
    thanks for sharing but got a similar problem too. hope someone from this thread would give a definite answers to my problem. thanks in advance.
    GHS Solutions
    Snowboard Reviews
  • Jiggy Gaton
    August 16, 2010 at 2:34 am
    Not sure if the answer is in this tut or not, but it might be worth a go thru:
    https://www.gomediazine.com/tutorials/photoshop/illustrative-typography/
    When I did, I remember there was not a lot of control over the pieces using Explosion FX / Explosion but the technique used in the tutorial was pretty good.
    Good luck!
    coocoo
