Activity Forums Adobe Premiere Pro Cutting thru multiple layers, deleting w/ripple, How?
  • Cutting thru multiple layers, deleting w/ripple, How?
    Posted by Eric Chard on June 23, 2023 at 4:18 am
    I’m cleaning up an ANCIENT video, and want to tighten it up (styles have changed in 20 years).
    I’d like to cut thru multiple layers , delete that chunk of time, and have the deletion ripple close.
    EG: there’s a text layer, a matte color layer, and the video. I’d like to slice all 3, and delete them ‘shut’, in the most efficient manner possible. TNX!
    Mark Dagostino replied 3 years, 1 month ago 3 Members · 2 Replies
    June 23, 2023 at 10:59 am
    Hey Eric,
    CTRL + SHIFT + “K” (on PC) will cut through everything.
    Except for locked tracks in the sequence.
    If you use: CTRL + ALT + “K”, that should open your Keyboard Shortcuts panel.
    Which may be helpful if you’re stuck.
  • Mark Dagostino
    June 25, 2023 at 12:32 pm
    Maybe make a nest of the three tracks and cut from that single track?
