Activity Forums Maxon Cinema 4D Cutting pieces off an object?
  • Cutting pieces off an object?
    Posted by Caroline Anthony on October 19, 2015 at 5:36 pm
    Hey all,
    I’m trying to create an animation where pieces of an object are being ‘sliced’ off. I tried using boolean but when I applied soft body to the new individual pieces, they sort of exploded. I’ve tried a bunch of other things, but I was wondering if anyone had any tips/techniques for simulating this?
    Caroline Anthony replied 10 years, 10 months ago 2 Members · 2 Replies
  • Brian Jones
    October 20, 2015 at 6:10 pm
    Are the new pieces still objects in a Boole or are they made editable? – if they are editable did you Connect the resulting objects? If you did Connect (or Connect and Delete) did you select all the vertexes and run Optimize so all the objects are one piece?
  • Caroline Anthony
    November 3, 2015 at 3:37 pm
    Hey Brian,
    I did not see your response till now. I had to find a workaround for that particular project, but thank you for your insight. I’ll have to give that a try.
