Activity › Forums › Compression Techniques › cutting iFrame only media
  • cutting iFrame only media
    Posted by Mohammad Torabi on April 28, 2015 at 5:13 pm
    I have created an iFrame only MXF file by the command below using FFmpeg:
    value of -ss and -t is base on nearest iFrame before the mark-in and after mark-out.
    [code]ffmpeg -ss 3020.58 -i “input file name.MXF” -t 20.5205 -threads 4 -pix_fmt yuv420p
    -flags +ildct+ilme -vcodec mpeg2video -top 1 -dc 10 -intra_vlc 1 -qmin 1 -lmin 1*QP2LAMBDA -vtag xd5c -g 0 -rc_max_vbv_use 1 -rc_min_vbv_use 1 -b:v 35000k -bufsize 35000k -minrate 35000k -maxra
    te 35000k -aspect 16:9 -vf “scale=-1:1080” -r 29.97 -f mxf -y “iFrame Only output file name.MXF”
    [/code]
    the log of running command is below:
    [code]ffmpeg version N-71737-gb410c69 Copyright (c) 2000-2015 the FFmpeg developers
    built with gcc 4.9.2 (GCC)
    configuration: –enable-gpl –enable-version3 –disable-w32threads –enable-avisynth –enable-bzlib –enable-fontconfig –enable-frei0r –enable-gnutls –enable-iconv –enable-libass –enable
    -libbluray –enable-libbs2b –enable-libcaca –enable-libdcadec –enable-libfreetype –enable-libgme –enable-libgsm –enable-libilbc –enable-libmodplug –enable-libmp3lame –enable-libopencor
    e-amrnb –enable-libopencore-amrwb –enable-libopenjpeg –enable-libopus –enable-librtmp –enable-libschroedinger –enable-libsoxr –enable-libspeex –enable-libtheora –enable-libtwolame –en
    able-libvidstab –enable-libvo-aacenc –enable-libvo-amrwbenc –enable-libvorbis –enable-libvpx –enable-libwavpack –enable-libwebp –enable-libx264 –enable-libx265 –enable-libxavs –enable
    -libxvid –enable-lzma –enable-decklink –enable-zlib
    libavutil 54. 23.101 / 54. 23.101
    libavcodec 56. 35.101 / 56. 35.101
    libavformat 56. 31.100 / 56. 31.100
    libavdevice 56. 4.100 / 56. 4.100
    libavfilter 5. 14.100 / 5. 14.100
    libswscale 3. 1.101 / 3. 1.101
    libswresample 1. 1.100 / 1. 1.100
    libpostproc 53. 3.100 / 53. 3.100
    Guessed Channel Layout for Input Stream #0.1 : stereo
    Input #0, mxf, from ‘input file name.MXF’:
    Metadata:
    uid : adab4424-2f25-4dc7-92ff-29bd000b0000
    generation_uid : adab4424-2f25-4dc7-92ff-29bd000b0001
    company_name : FFmpeg
    product_name : OP1a Muxer
    product_version : 54.63.104
    product_uid : adab4424-2f25-4dc7-92ff-29bd000b0002
    modification_date: 0000-01-01 00:00:00
    material_package_umid: 0x060A2B340101010501010D0013E00EE4529471344CE00EE400529471344CE000
    timecode : 00:00:00;00
    Duration: 01:00:00.03, start: 0.000000, bitrate: 4592 kb/s
    Stream #0:0: Video: mpeg2video (Main), yuv420p(tv, unknown/bt709/bt709), 1920×1080 [SAR 1:1 DAR 16:9], max. 35000 kb/s, 29.97 fps, 29.97 tbr, 29.97 tbn, 59.94 tbc
    Metadata:
    file_package_umid: 0x060A2B340101010501010D0013E00EE4529471344CE00EE400529471344CE001
    Stream #0:1: Audio: pcm_s24le, 48000 Hz, 2 channels, s32 (24 bit), 2304 kb/s
    Metadata:
    [mpeg2video @ 0000000004edd140] Warning vbv_delay will be set to 0xFFFF (=VBR) as the specified vbv buffer is too large for the given bitrate!
    Output #0, mxf, to ‘iFrame Only output file name.MXF’:
    Metadata:
    encoder : Lavf56.31.100
    Stream #0:0: Video: mpeg2video (xd5c / 0x63356478), yuv420p, 1920×1080 [SAR 1:1 DAR 16:9], q=1-31, 35000 kb/s, 29.97 fps, 29.97 tbn, 29.97 tbc
    Metadata:
    encoder : Lavc56.35.101 mpeg2video
    Stream #0:1: Audio: pcm_s16le, 48000 Hz, stereo, s16 (24 bit), 1536 kb/s
    Metadata:
    encoder : Lavc56.35.101 pcm_s16le
    Stream mapping:
    Stream #0:0 -> #0:0 (mpeg2video (native) -> mpeg2video (native))
    Stream #0:1 -> #0:1 (pcm_s24le (native) -> pcm_s16le (native))
    Press [q] to stop, [?] for help
    [mxf @ 0000000002d98440] -d10_channelcount requires MXF D-10 and will be ignored
    frame= 615 fps=313 q=0.8 Lsize= 91196kB time=00:00:20.52 bitrate=36406.4kbits/s
    video:86605kB audio:3848kB subtitle:0kB other streams:0kB global headers:0kB muxing overhead: 0.822079%[/code]
    then used the iFrame only file as input file and the command below to cut a chunk of it.
    [code]ffmpeg -ss 0.2002 -i “iFrame Only output file name.MXF” -c:v copy -t [b]19.9533[/b] -an -f MXF -y “iFrame Only Video_1.MXF”
    [/code]
    the log of the command is:
    Input #0, mxf, from ‘iFrame Only output file name.MXF’:
    Metadata:
    uid : adab4424-2f25-4dc7-92ff-29bd000c0000
    generation_uid : adab4424-2f25-4dc7-92ff-29bd000c0001
    product_version : 56.31.100
    product_uid : adab4424-2f25-4dc7-92ff-29bd000c0002
    material_package_umid: 0x060A2B340101010501010D001346374B529471349946374B0052947134994600
    Duration: 00:00:20.52, start: 0.000000, bitrate: 36406 kb/s
    Stream #0:0: Video: mpeg2video (Main), yuv420p(tv), 1920×1080 [SAR 1:1 DAR 16:9], max. 35000 kb/s, 29.97 fps, 29.97 tbr, 29.97 tbn, 59.94 tbc
    Metadata:
    file_package_umid: 0x060A2B340101010501010D001346374B529471349946374B0052947134994601
    Stream #0:1: Audio: pcm_s16le, 48000 Hz, 2 channels, s16, 1536 kb/s
    Metadata:
    Output #0, mxf, to ‘iFrame Only Video_1.MXF’:
    Metadata:
    Stream #0:0: Video: mpeg2video, yuv420p, 1920×1080 [SAR 1:1 DAR 16:9], q=2-31, max. 35000 kb/s, 29.97 fps, 29.97 tbr, 29.97 tbn, 29.97 tbc
    Metadata:
    Stream mapping:
    Stream #0:0 -> #0:0 (copy)
    frame= 600 fps=0.0 q=-1.0 Lsize= 85564kB [b]time=00:00:19.98[/b] bitrate=35070.5kbits/s
    video:84986kB audio:0kB subtitle:0kB other streams:0kB global headers:0kB muxing overhead: 0.679815%
    [/code]
    as you can compare the command and log, value of -t in command is 19.9533 and time in log is 19.98. (the log shows that the output is one Frame longer). but when I check the specs of output by MediaInfo it show that the duration is 20.020 (two frames longer than the command).
    any comments or suggestion on why it happens?
    thanks
    Mohammad Torabi replied 11 years, 5 months ago 1 Member · 0 Replies
  • 0 Replies
