Activity Forums Adobe Premiere Pro Cutting clip = re- render??
  • Cutting clip = re- render??
    Posted by Anthony Faulkner on September 30, 2015 at 1:55 am
    I’m fairly new to Premiere pro CC, having just switched from FCP7. I have this issue and I wonder if anyone can help.
    Hi Have a fairly heavy composite clip, Lots of filters on the keyed clip with animated backgrounds making the render time about an hour. The issue I am having is that I need to trim the starts and ends of the video and add an outro logo.
    I can trim all the five video/ image layers and there is no re-rendering required, but if I try to trim the bottom layer (a psd) it will set the entire sequence to red and require re rendering.
    I can add a fade to it no problem, I can change layers, no problem. But if i use the razor, or shorten it the entire thing needs to be rendered again.
    Very annoying given the amount of time that I have to sit while it renders again.
    Any clue as to a way around this?
    Anthony Faulkner replied 10 years, 11 months ago 3 Members · 5 Replies
