Activity Forums Adobe Premiere Pro Cutting audio/video in Premiere Pro CC without it loosing sync
  • Cutting audio/video in Premiere Pro CC without it loosing sync
    Posted by Chris Hill on December 5, 2014 at 2:55 am
    Hey all, veteran (I guess) PP user, and don’t ask for system specs, I know its not a comp issue, just built this AMD FX8320, 3.5GHZ 8 core with 8GB ram and 2GB graphics with a samsung SSD….windows 7PRO!
    That being said, lol, I am having an issue (In Premiere Pro CC) with using the razor tool and loosing audio sync. I bring in a video channel w/ audio, and then a separate audio track, we used claps (no visual clapper, just audio) to sync the audio tracks. Its all well and good and the sound is spot on, but I need to make cuts for episodes, and when i make a cut, the audio (that isn’t attached to the video track), is off my 1-1.5 frames….thoughts, I have to make many cuts so having to zoom in/out over and over to nudge the audio track is very annoying and frustrating because it never sounds 100% like when I first lined them up with the claps. I have used the “show audio time units” but regardless every new cut, the audio is a smidgen off, and its irritating.
    Is there a simple remedy?
    Chris Hill replied 11 years, 2 months ago 4 Members · 6 Replies
  • Zoë Davis
    December 5, 2014 at 1:17 pm
    Silly question perhaps, but is your snap de-selected?
  • Jake Abramson
    December 5, 2014 at 9:47 pm
    What is the video file format? I find some of the long GOP frame video formats lose sync with the audio portion. Converting to something more edit friendly usually does the trick.
  • Chris Hill
    December 7, 2014 at 11:37 pm
    Snap was de-selected, maybe I will try cutting with snap on. Thanks, see silly things go out the window sometimes when you are focused in on different things.
  • Chris Hill
    December 7, 2014 at 11:40 pm
    pretty standard, MP4’s thank you for your reply.
  • Simon Osborn
    June 29, 2015 at 10:05 pm
    Hi Chris,
    Was this ever solved? Currently having problems importing FarCry4 mp4 files with the same issue, video/audio is out of sync, even before I cut the file. It plays perfectly in KMPlayer. Snap is on ;)…
  • Chris Hill
    June 30, 2015 at 12:10 am
    Sorry Simon I never found an resolution, I have tried (snap on/off, etc.) I just pay super close attention to when I make a cut if there is some sync issues. For some reason as I make more and more cuts, One audio channel is off.
    I use shit+click for razor tool now and it cuts all lines (audio+video)
    Your issue sounds very different, the audio is out of sync when you import? Has it trans-coded everything yet? Or “index” I guess is the term. Sometimes, If I have left my Premiere CC open too long the video freezes in the preview window. Closing/opening the program helps me, not sure if that will help you. Best of luck!
