Activity Forums Maxon Cinema 4D cutting a spline?
  • cutting a spline?
    Posted by Robyn Rhodes on May 9, 2011 at 7:15 pm
    Very simple ?.
    I’ve created circle spline and made it editable. I want to cut the spline so that it’s disconnected where I cut it. The knife I thought was the tool for the job. However this seems only to “add” a point.
    thx,
    r
    I’m only half the thing I say I am, the other half are me.
    Robyn Rhodes replied 15 years, 3 months ago 3 Members · 3 Replies
  • Brian Jones
    May 10, 2011 at 3:31 am
    use the knife or the add point tool to make the ‘cut’ then use Functions/Disconnect, that will give you a point (still selected) you can delete or move and delete and in the original spot is two points which can be moved apart (or whatever).
  • Adam Trachtenberg
    May 10, 2011 at 5:45 pm
    Also, make sure you uncheck “close spline” in the AM.
  • Robyn Rhodes
    May 10, 2011 at 10:40 pm
    thanks guys
    r
