Activity Forums Maxon Cinema 4D Cutting a spline with a polygon object
  • Cutting a spline with a polygon object
    Posted by Fabio Bressan on May 25, 2012 at 2:27 pm
    Hello, I’ve found several techniques about how to cut a polygon object with a spline, but I need to the opposite and I can’t find a clue on how to do it.
    Basically I have a straight line (spline) intersecting with an object and I need to get only the points of intersection.
    This: https://dl.dropbox.com/u/4576308/splineintersect.jpg
    I need to find a process to do this automatically (I’ll use a grid of those spline lines intersecting an object to obtain a point cloud), but not dinamically (I mean as the animation plays …). I’d do it at editing/modeling stage. Ideally a Boole intersection would serve, but unfortunately splines can’t be used with Boole!
    Any idea? Thank in anticipation to anybody who will help!!
    Fabio Bressan
    Brian Jones replied 14 years, 3 months ago 2 Members · 1 Reply
  • Brian Jones
    May 26, 2012 at 4:59 am
    unless someone has a dedicated plugin maybe the Ray Collision node in xpresso has some chance if you are handy enough in xpresso… and assuming it’s possible
