Activity › Forums › Apple Final Cut Pro Legacy › Cutting a project from ProRes 422 HQ
Rafael Amador replied 15 years, 4 months ago 7 Members · 21 Replies
Rafael Amador
April 30, 2011 at 8:10 am[Damon Packard] “really all those semi confusing labels and codecs and formats mean to me is, “stuff that will not work on your machine because you don’t have thousands of dollars to upgrade your hardware” “
Labels shouldn’t be a problem when you know what you are looking for.
So spend some time and document your self about Prores (Google Prores White Papers).You can READ any Prores flavor with just QT Pro 7, but to export to Prores you need at least FC.6.
You does’t need any Intel Mac.[Chris Borjis] “and as far as intel processors required….yes but only for capturing.
you cannot capture pro res hq in HD on even a quad G5.
I used to have one and it never worked even though apple said it would.”
No problem with a G5.
When capturing through an ioHD, the burden of the processing is in the card. The computer basically just write the file in the HD. A HD fast enough is all what you need.
rafael
