Activity Forums Adobe After Effects cutting a person out
  • cutting a person out
    Posted by Donato M. rondinelli on October 26, 2006 at 1:58 pm
    I want to remove someone from the background. He’s on a stage & I was able to key out the blue wash on the wall behind him. So he’s cut out until he takes a few steps & stops in front of an area that didn’t key out. The area is a slash of light on a texture & the color is very close to his skin tone. Is their something that can take this out automatically? It’s a :10 clip so I tried to rotobezier a mask but it looks weak. Did I mention that he moves a lot?
    Help.
    -dMR
    Donato M. rondinelli replied 19 years, 10 months ago 3 Members · 4 Replies
  • Donato M. rondinelli
    October 26, 2006 at 2:16 pm
    I’m using AE7 Pro on a Mac.
  • Steve Roberts
    October 26, 2006 at 2:25 pm
    Try to key out what you can, then rotoscope out the rest manually. It’s painstaking work, but you may find some tips if you search for “roto” at the COW.
  • Nicholas Toth
    October 26, 2006 at 2:28 pm
    Options
    1. ROTOSCOPE him out. I know you said you did — but go back and pump the iTunes and re-do it. (this sounds like the right way to go)
    2. Mess with your levels. Throw on a threshold, add some blur, and try to use it as a luma/inverted luma matte as you see fit. You may need multiple layers. (somewhat quick easy dirty fix)
    October 26, 2006 at 3:07 pm
    >>>…pump the iTunes…
    That was the first thing I did!
    >>>…You may need multiple layers.
    I didn’t consider this. I was trying to everything with one mask.
    -dMR
