Activity › Forums › VEGAS Pro › Cuts and Fades = Artifacts and Issues
  • Cuts and Fades = Artifacts and Issues
    Posted by Brett Nolan on August 26, 2009 at 4:26 pm
    You guys have been so much help in the past, thank you for everything you do.
    I’ll try to make sense on this as I’m not sure how to describe the problem I’m having. I am cutting a music video with a lot of syncopated cuts and flashes. I’m seeing horizontal lines and artifacts drawn on my fades and cuts as video clips transition from one another. Could this be related to the field order settings ?, my footage is HDV 1080 MT2 1440X1080 and the raw footage was assigned an “upper field first” field order setting upon capture.
    I’ve had this issue before in some of my productions, not sure what’s causing it but I’ve had a few clients comment on it, and I’m wanting to take the steps to avoid it in the future.
    https://www.youtube.com/watch?v=JKmA5ojmF4U
    <---there's an example of an old production I did that has some of what I'm talking about in it. Any help you guys might offer would be eternally appreciated. Thanks in advance.
    Brett Nolan replied 17 years, 1 month ago 1 Member · 0 Replies
  • 0 Replies
