Activity Forums Adobe After Effects cut vid in half and place 2nd half under first AE5
  • cut vid in half and place 2nd half under first AE5
    Posted by Gary Jarvis on December 8, 2013 at 3:37 pm
    hey guys,
    I have a LED wall that is 2224px x 96px my processor only goes up to 1920px wide.
    What I would like to do is cut it in half 1112px x 96 and then, bring the second half and place it under the 1st half. I can then lay out my tiles in two rows numerically to run as 2224px.
    Thanks Gary
    George Goodman replied 12 years, 9 months ago 3 Members · 5 Replies
  • Gary Jarvis
    December 9, 2013 at 7:08 pm
    Thanks for your response Dave,
    The basic logic is that the processor in question has input and output cards, the max out put is 1920 x 1080, the actual size of the wall is 2112 x 96 and hey mate there is nothing I can do about, it’s all I have to work with.
    So, what can I do to make this work, (the show must go on) what I think I can do is to bring two versions of the vid into AE cut both of them in half i.e top one 1st half 1006 x 96 2nd layer I use the last half, I then dragged the lower 1/2 under the under the top half and hopefully create a 1006 x 192 vid and rendered a movie.
    In my LED wall software I can create two rows of tiles, the top one being 1 thru 11 and the bottom one 12 thru 22.
    The question I have is, how do I merge the two vids?
    Gary
  • Walter Soyka
    December 9, 2013 at 7:35 pm
    [Dave LaRonde] “I can see no reason why you should be constrained to 1920×1080, no matter what kind of card is in your machine.”
    When Gary refers to a processor, he’s talking in this case about the device that actually controls the LED tiles. It has a live 1920×1080 input (via HD-SDI or DVI), and for 1:1 mapping onto his tiles, he needs to provide the output to the wall within a 1920×1080 frame.
    In other words, instead of providing video that looks like this:
    1234567890
    He has to provide video that looks like this so it fits inside the raster:
    12345
    67890
    And then the LED processor can re-map it back to 1234567890 on the tiles.
    Gary, I don’t really understand what your sources here are. Are you starting with a 2112×96 piece of footage or comp?
    If so, probably the easiest way to conceptualize this is to create a 1056×96 comp and drop your 2112×96 footage into it. Select the footage layer, hit the A key for anchor point and set this to [0,0]. Hit the P key for position and set this to [0,0]. This will position the upper left corner of the footage at the upper left corner of the comp, giving you one half of the image.
    Duplicate the comp. Open up the new comp and select the footage layer. Hit the A key for anchor and set this to [1056,0]. This will slide the footage over, giving you the other half.
    Create a 1920×1080 comp, drop both of these precomps in, and position as necessary.
    Walter Soyka
  • Gary Jarvis
    December 9, 2013 at 9:47 pm
    Thank you Walter for clarifying my situation and thanks for your answer, I’ll put it together tonight.
    My apologies for not being clear enough Dave and, do appreciate your participation
    All the best guys and thanks
    Gary
  • George Goodman
    December 11, 2013 at 10:07 pm
    I’m a little unclear on what your source is as well, but could you just drop the footage in a 1920×1080 comp and use CC RepeTile?
    _ _
    (°_0)/
    Sincerely,
    George
  • George Goodman
    December 11, 2013 at 10:14 pm
    To be more clear:
    Take the footage, mask the first half, duplicate it, change the mask to subtract, place it underneath the first one manually, precomp it (making sure the comp settings match the size, bring that into a new comp of the size you want (1920×1080?) and use CC repetile
    I think that’ll do what you’re looking for, but I’m not totally sure.
    Anyway, hope that’s helpful
    _ ,,,,, _
    (°_0)/
    Sincerely,
    George
