Activity Forums Maxon Cinema 4D cut spline hole in a surface
  • cut spline hole in a surface
    Posted by Alan Lacey on May 22, 2005 at 6:37 pm
    Is it possible to do this.
    Given a closed spline on a surface can you remove the area enclosed leaving a hole?
    On another tack how can you prevent thinking particle geometry passing through each other? I’ve built a stream of particles moving down a tube and want them to bounce off each other rather than pass through each other.
    Thanks for any help.
    Alan
    Brian Jones replied 21 years, 3 months ago 3 Members · 6 Replies
  • Brian Jones
    May 23, 2005 at 6:34 am
    [alan lacey] “Given a closed spline on a surface can you remove the area enclosed leaving a hole?
    Extrude the spline through the surface and use a Boolean – A without B
    More ways?…
  • Alan Lacey
    May 23, 2005 at 4:02 pm
    Ooooo! that didn’t occur to me.
    Thanks Brian
  • Adam Trachtenberg
    May 24, 2005 at 12:59 pm
    Arndt’s Edge Extrude Pro plugin is still the best way to cut holes with splines–as it preserves quads around the edge. It’s available in the Dairy Store.
    Regarding the particles, you can use the “TP Particle Collision” object in Objects>Object Library. You just have to click on the object in the OM and drag in the names of your particle groups.
  • Alan Lacey
    May 24, 2005 at 4:46 pm
    Thanks a lot Adam
    Alan
  • Alan Lacey
    May 24, 2005 at 5:56 pm
    Adam,
    Do you happen to know if the Edge extrude plugin works with c4d vers 9?
    Alan
  • Brian Jones
    May 24, 2005 at 10:25 pm
    It works for me
