Activity Forums Adobe After Effects Cut out animation
  • Cut out animation
    Posted by Y. Bar on October 14, 2009 at 12:13 pm
    Hello,
    I am working on cut out animation in After Effects, and in one scene for example – my character is made up of 6 parts (2 legs, each composed of UPPER_LEG, LOWER_LEG, FOOT ).
    All these layers are parented, and I set their joints using the pan behind tool.
    When I am working on my animation, I need to create for each point in time keyframes for all these layers, for the position, rotation and opacity attributes.
    My question is – is there a quick way – with one button for instance – to set keyframes for numerous layers and numerous attributes? That would simplify my work a lot.
    And if anyone knows of good plugins that can aid my cutout animation in other ways, I appreciate if he can tell me about them.
    Thank you,
    Y.
    Y. Bar replied 16 years, 11 months ago 2 Members · 4 Replies
  • Brian Charles
    October 14, 2009 at 3:09 pm
    I don’t know of any keyboard shortcut that would help you other that setting initial keyframes for properties (alt+P adds position, alt+r adds rotation).
    I thought that Dan Ebberts terrific IK script might help, you can find it at the bottom of this page:
    https://www.motionscript.com/design-guide/toc.html
  • Y. Bar
    October 15, 2009 at 2:06 am
    the link you posted doesn’t seem to work.
    I really don’t know anything about scripts, but if there isn’t a keyboard shortcut, or a plugin for this , would it perhaps be possible to create a set of keyframes in a previously defined list (for example, Layer1:Rotation,Opacity,Position. Layer2: Opacity. and so on ) using a script ?
    Thanks for your reply,
    Y.
  • Brian Charles
    October 15, 2009 at 2:04 pm
    For some reason the link added 2
    characters.
    Just go to https://www.motionscript.com
    I’m not aware of any method to read a list of multiple properties and apply them. Expressions and scripts may be your only hope.
    Anyone else??
  • Y. Bar
    October 16, 2009 at 6:03 am
    Thanks, I’ll try it with the scripting way.
    Y.
