Activity › Forums › Apple Final Cut Pro Legacy › cut forces re-render
  • cut forces re-render
    Posted by Peter Ralph on June 9, 2006 at 3:05 pm
    two video tracks – filters applied to both.
    under some circumstances razor-blading the lower clip will force the whole clip to re-render.
    Anyone know why this happens or how to avoid it?
    Kevin Monahan replied 20 years, 3 months ago 4 Members · 4 Replies
  • John Pale
    June 9, 2006 at 3:41 pm
    some types of filters effects are dependent on the length of the clip. if the clip gets shorter (by a cut) then the effect needs to be recalculated.
  • Jonathan Palmer
    June 9, 2006 at 4:11 pm
    when I encounter this I’ll just blade a small section that im working on so that’s all I render each time
    JP
  • Peter Ralph
    June 9, 2006 at 4:24 pm
    this is happening with color correction filters and the like which are not dependent on the clip length, or at least shouldn’t be…
  • Kevin Monahan
    June 9, 2006 at 6:33 pm
    Try using the trim tools. Very rarely do you actually need to use the Blade Tool. A trim should not foil your renders.
    Kevin Monahan
    Take My FCP Master’s Workshop!
    fcpworld.com
