Activity › Forums › Apple Final Cut Pro Legacy › Cut Detection
Cut Detection
Posted by Jase on January 6, 2006 at 8:27 pmJust wondering if anyone has found a cut detection plug for FCP…doing a cut of 4 cam mix of some bands and have to grade each cam – which means finding the cut points…
cheers
JaseDavid Wishnie replied 18 years, 5 months ago 6 Members · 6 Replies -
Mark Maness
January 6, 2006 at 9:10 pmOnly in DV…
_______________________________
Wayne Carey
Schazam Productions -
Jase
January 6, 2006 at 9:42 pmThe 4 cam mix is on dv tape….as I understand it, it only works on time of day for detection….would it work if the timecode is continuous?
Jase
Martin Baker
January 6, 2006 at 9:49 pmThere is an app called Toki Shot which will do shot detection on a QT movie and save it as an EDL:
https://www.tokitest.com/tokishot/index_en.html
Martin
Digital Heaven, London UK
________________________________________
NEW! MovieLogger – QuickTime logging made simple -
Thaxter Clavemarlton
January 6, 2006 at 10:17 pm[Jase] “would it work if the timecode is continuous?”
Nope.
As you say, it looks at the time differences.
As I recall, iMovie has SCENE-CHANGE detection.
If you can get that to work (easy enough to TRY it), you could capture with iMovie and import the clips into FCP.
Dan Montgomery
January 18, 2006 at 4:32 pmHD Log can handle both DV and color based scene detection, as well as TC breaks. It can also do this from QT file, FireWire connection or analog video feed. http://www.imagineproducts.com/hdlog.htm
Video logging is just the beginning…
David Wishnie
March 10, 2008 at 6:13 pm
