Activity Forums VEGAS Pro Cut away mouth
  • Cut away mouth
    Posted by Morty Aronsen on November 9, 2008 at 2:13 pm
    Hello!
    I`m working on a prosject where I need to cut away the mouth in a portrait. I will cahnge them to somone elses mouth. How do I do this in Vegas 7?
    John Rofrano replied 17 years, 10 months ago 3 Members · 4 Replies
  • Mike Kujbida
    November 9, 2008 at 3:24 pm
    A bezier mask (part of Pan/Crop) with feathering would probably be the best tool to use for this.
    Depending on how closely the two shots match, you may need to do some keyframing to keep it looking realistic.
  • John Rofrano
    November 9, 2008 at 3:39 pm
    Go into Pan/Crop on the image event and use the Mask tool to create a mask around the mouth. Set the mask Mode to Negative to create a hole in the image where the mouth once was.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Morty Aronsen
    November 9, 2008 at 9:09 pm
    Is it possible to crop and move the mask around to make it fit? I couln`t figure out how to do it in mask mode.. Do you use another effect to make it more realistic.. Make the edges smoother for example..
    M
  • John Rofrano
    November 9, 2008 at 9:43 pm
    You can animate the mask by adding keyframes. You can soften the edges by using the feather type in the mask tool.
    ~jr
