Activity Forums Apple Final Cut Pro Cut and Paste effects does not always work
  • Cut and Paste effects does not always work
    Posted by Patrice Freymond on July 13, 2011 at 3:55 pm
    been playing with transforms and so on today and here at least the paste effects (alt cmd V) does not work from the keyboard but works sometimes from the Edit Menu.
    In most cases what gets pasted is the last keyframe of the animated transform. Sometimes I can see all three keyframes but the clip will remain inanimated, having only the parameters of one of the KF applied.
    Also, I find it very annoying that the skimmer does not work when using the transform button, only the playhead works.
    Anybody see the same things happen or have solutions to that?
    Thanks in advance
    Patrice
    Patrice Freymond replied 15 years, 1 month ago 1 Member · 1 Reply
  • Patrice Freymond
    July 13, 2011 at 4:39 pm
    Adding to the above, it turns out that pasting static effects, i.e non keyframed over time, works. But as soon as I copy an opacity change or an animated 50’s TV effect, only part or none of the effect is copied.
    patrice
