Cut and paste a section of a clip?
Hello!
I truly apologize if this has been covered before, but I have looked through archives and could not find it.
Is there a way to select just a piece of a clip with in and out, cut it (or copy it) from the sequence and then paste it somewhere else in the sequence?
Essentially, I am looking for the equivalent of FCP cmd+x then cmd+v or AVID’s opt+cntrl+X, which will cut the selection and immediately place it in the clipboard for editing into the sequence somewhere else.
Currently, if I try to do the FCP keyframes, I get a completely different piece of video than I wanted.
A workaround has been to cmd+X and then cmd+Z – that’s how I get the video I want in the clipboard – and then go to the new edit point and cmd+V. The other alternative would be to use the blade to create a new clip, but that also is about 4 keystrokes.
I am such a newbie at this, I apologize. Trying to wrap my old brain around the new application.
– Caroline
