Activity Forums Maxon Cinema 4D Cut a hole in a cylinder
  • Cut a hole in a cylinder
    Posted by Grant Strac on January 6, 2014 at 6:03 pm
    I am creating a tripod speaker stand and I have all the pieces below the (belt) middle screw. So in the main cylinder I duplicate my object and decrease the size slightly so it Looks like it fit’s inside the bottom cylinder. Now I want to add pin holes up the top cylinder. The tripod works by pulling a pin and sliding the top tube up and putting the pin back in….but how can I cut a hole inside the cylinder to make this effect?
    I figured everything out except putting the hole in the cylinder.
    Grant Strac replied 12 years, 8 months ago 2 Members · 2 Replies
  • Brian Jones
    January 7, 2014 at 1:42 am
    check out the Boole Object
  • Grant Strac
    January 7, 2014 at 3:13 pm
    Thank you Brian I am going to try that now. I appreciate your response.
