Activity › Forums › Adobe Premiere Pro › Customs speeds
Customs speeds
Posted by Shaun999 on April 13, 2005 at 6:56 pmHi,
Does anyone know you you can create customs speeds ? ie if i take a piece of footage can i automate speed changes so that i start a one speed and gradually get faster and faster ?
ShaunShaun999 replied 21 years, 5 months ago 4 Members · 7 Replies -
Steven L. gotz
April 13, 2005 at 8:51 pmIt is not possible in Premiere Pro without cutting up the clip into short durations and changing each portion a little bit different than the last portion.
You want After Effects to you can use Time Remapping.
Steven
Adobe Premiere Pro 1.5 / After Effects 6.5 Pro https://www.stevengotz.com
Learning Adobe Premiere Pro 1.5 https://www.lynda.com
Contributing Writer, PeachPit Press, Visual QuickPro Guide, Premiere Pro 1.5 -
Shaun999
April 14, 2005 at 12:13 amSo their aren’t any speed changing plugins on the market – ones that i could automate/animate ?
Shaun
John Hand
April 14, 2005 at 1:21 amLatest version of Twixtor (4.5 I believe) will do this within Premiere Pro. The slow motion quality in Twixtor is about 100% better than in AfterEffects.
good luck,
Jon R Hand -
Ralph Keyser
April 14, 2005 at 11:03 pmAh, the old speed ramp effect. I think the Twixtor (sp) plug-in gives you keyframable animation of frame rates. Their interpolation is better than PPro’s too. Goggle should find it for you, I don’t recall who makes it. Vision effects?
