Activity › Forums › Avid Media Composer › Customizing Keyboard
  • Customizing Keyboard
    Posted by Reuben Fink on August 24, 2009 at 8:31 pm
    Hello,
    I’m learning MC this week. I’m a FCP user transitioning over to Avid for a new job. I was hoping to copy a lot of the shortcuts that I’m already used to. So far so good until l needed to map the command key or option key. Doesn’t seem to work. I’ve had success with the shift key that’s it.
    Is it doable in MC?
    OSX 10.5.8
    Equipment: 2.8 ghz 8 core Intal Mac Pro, 20 gig of ram
    Aps: CS3 Production Bundle, FCP Suite 2, Avid Media Composer
    Reuben Fink replied 17 years, 1 month ago 2 Members · 2 Replies
  • Michael Hancock
    August 24, 2009 at 9:33 pm
    Nope. You can map the standard keys and Shift+standard keys, but can’t map Cmd+Keyboard, Alt+Keyboard, or Ctrl+Keyboard. In this way, Avid is less keyboard mappable than FCP.
    That said, I highly suggest you start with the Avid default keyboard layout and get used to it. It’s been refined over the last 15 years or so to reflect the most commonly used functions and is, in my opinion, much more logical than FCP’s. Plus, there are commands in FCP that don’t translate to Avid and vice versa, so it’s typically best to learn it the Avid way then change it if you don’t like it. Because if you try to drive Avid like you drive a FCP system you’ll go insane.
    Michael
    I’ll be working late.
  • Reuben Fink
    August 25, 2009 at 4:02 am
    Thanks for the reply. I’ll stop trying to find a way 🙂
    In regards to mapping custom keys, the way I cut in FCP is very similar to how I’m learning to cut in Avid. So I really don’t think I would go that crazy. In a lot of ways I’m finding quite a few similarities. Then again maybe I’m already crazy.
