Activity Forums VEGAS Pro Customizing DVDA 3 settings
  • Customizing DVDA 3 settings
    Posted by Paul Gregory on December 23, 2006 at 12:09 am
    I know a few of the options using DVDA 3 can be set in advance but what about others?
    By that I mean to always start a project with things like the reduce de interlace flicker setting always turned on. I can’t imaging what anyone would ever want it off.
    If you always like thumbnail buttons say underlined with the color of your choice rather than as than the large yellow highlight. There are lots of other settings that get used but I tend to use mainly the same ones for ever project.
    Thanks in advance
    Gary Kleiner replied 19 years, 8 months ago 2 Members · 1 Reply
  • Gary Kleiner
    December 23, 2006 at 4:51 am
    You can save your current choices by saving them as a theme.
    File > Export menu as theme.
    To apply it later to a menu you are working on, go to the theme tab and double-click on the theme you saved.
    Gary Kleiner
    Vegas Training and Tools.com
    Learn Vegas and DVD Architect
    http://www.VegasTrainingAndTools.com
