Activity Forums Adobe After Effects Customizing a Slider Control range?
  • Customizing a Slider Control range?
    Posted by Bert Brown on August 27, 2008 at 6:19 pm
    I’m thinking it’s not, but is it possible to change a Slider Control’s 0-100 range? Like, literally what you see in the Effects Controls window (as opposed to some sort of expressions relationship) ?
    peep my over-the-interweb band, red abbott.
    “we electro-rock over long distances…”
    Andrey Khvostenko replied 11 years, 6 months ago 3 Members · 3 Replies
  • Darby Edelen
    August 27, 2008 at 6:40 pm
    Right click the Slider Control’s Slider property and go to “Edit Value…”
    Above the ‘Value’ field in the resulting dialog there is a ‘Slider Range’ section where you can set the range of the slider. This only applies to the visual representation of the slider; the values can still range anywhere between -1000000 and 1000000.
    Darby Edelen
    NVIDIA
    Santa Clara, CA
  • Bert Brown
    August 27, 2008 at 6:52 pm
    ahhh thank you. i was trying right click and i must have been just a little off (kept giving me my list of effects)
    too bad this is only visually, though. i was basically trying to keep the slider without having to clamp.
  • Andrey Khvostenko
    March 13, 2015 at 10:57 am
    Thank you man! It’s not the first piece of advice of yours, that helped me a lot!
    So this time I’ve decided to sign up to be able to say thanks a lot!!!
    Keep it up)
