Activity Forums VEGAS Pro customize keyboard shortcuts
  • customize keyboard shortcuts
    Posted by Rick Wise on May 29, 2008 at 8:05 pm
    I am trying to get Vegas 8 to view/minimize all tracks with the shortcut: ctrl+alt+m. I’ve gone to (options) customize keyboard, found the name, MinimizeAllTracks, added the shortcut in the shortcut keys window, and pressed OK. But the shortcut does not work. I tried saving a new keyboard map name with this shortcut. Still doesn’t work. I tried the shortcut ctrl+shift+alt+m, same dead end. I must be leaving something out here. Anyone know?
    Rick Wise
    director of photography
    Oakland, CA
    http://www.RickWiseDP.com
    email: Rick@RickWiseDP.com
    Rick Wise replied 18 years, 3 months ago 2 Members · 2 Replies
  • John Rofrano
    May 30, 2008 at 6:08 pm
    I’m not sure why this isn’t working for you. I just tried it and it works for me. Did you press Add before you pressed OK?
    You might want to look at TrackView.Zoom.MinTrackHeight. It’s already mapped to the tilde key (~) and also by double-clicking on the vertical scroll bar on the right side of the track view. Just use one of those two methods if you can’t get your other map to work.
    ~jr
    https://www.johnrofrano.com/
  • Rick Wise
    May 30, 2008 at 11:57 pm
    Thanks, John. Yes, the tilde works great. All I need. I wonder why the pull-down menu for “view” doesn’t list that shortcut while it does list others.
    As for not being able to customize the keyboard, that remains a mystery. Yes, I did press add. And each time I bring up “minimize” in the customize keyboard, the shortcut is listed. But it doesn’t’ work.
    Rick Wise
    Oakland, CA
