Activity Forums Adobe After Effects Custom Views/Camera
  • Custom Views/Camera
    Posted by Mark Hills on April 22, 2009 at 10:33 am
    Is there any way to export out a composition using a custom view as the active camera? It’s really frustrating not being able to at the moment and i was just wondering if someone could help me out here or tell me the custom view camera position details so that i could add a new camera in.
    Thanks a lot
    David Bogie replied 17 years, 5 months ago 2 Members · 1 Reply
  • David Bogie
    April 22, 2009 at 5:43 pm
    Nope. The question comes up about ten times a year and Adobe’s response is usually to submit a product enhancement request on the AE site at adobe.com.
    If you search for similar terms here on the cow, you should find an expression that mimics, sort of, the view of the custom view camera. The problem, IIRC, is that the custom view uses a completely different perspective processing that is not based a optical algorithm; you’re not really looking through a lens. Any real camera requires a lens.
    Hope someone else chimes in with a direct link to that expression for you.
    bogiesan
