Activity › Forums › Adobe After Effects › Custom View 3D Camera Question
  • Custom View 3D Camera Question
    Posted by David Gerberding on August 15, 2006 at 10:12 pm
    Tried this over on the COW with no answer. Maybe because it’s too basic?…
    I am looking at my 3D composition with “Custom View 1” selected. I like the angle, but for some reason have had a difficult time getting the comp camera in the same position. Is it possible to discover what position the “Custom View 1” camera is in, so that I can set my comp camera there? If not, is it possible to render out the view of “Custom View 1” so that I could use it as an element later?
    Stuart Dorrian replied 20 years, 1 month ago 3 Members · 4 Replies
  • Tim Kurkoski
    August 16, 2006 at 4:52 pm
    Not sure on this one. Have you tried leaving the comp set to Custom View and rendering it?
    Elsewise, I can only suggest trial and error to match that view. Maybe create a solid, position it so it exactly fills the custom view, then work on adjusting your camera to do the same thing.
  • Stuart Dorrian
    August 22, 2006 at 3:09 am
    Hi Dave, did you have any luck finding the position co-ordinates for the custom view cameras? I need the same thing myself! hope you can help! Thanks.
  • David Gerberding
    August 22, 2006 at 6:35 pm
    No firm info yet. I thought I heard Brian Maffitt mention it in one of the AE Total Training disks, but I havn’t been able to find the spot yet.
  • Stuart Dorrian
    August 22, 2006 at 8:48 pm
    keep me posted if you do. likewise. im gonna try a different cam angle altogether in my current project (the one i needed it for) but several times ive thought i would have been a good shot. thanks Dave.
