Activity Forums Apple Final Cut Pro custom titles
  • custom titles
    Posted by Roy Mckenzie on September 21, 2015 at 8:44 pm
    Has anyone else experienced this? I added a new custom title to the timeline and animated it on with the published parameters, but when I change the look to an outline (outline the text and turn off “face”) it only shows the outline after the animation!
    So during the animation on/off FCPX produces white text, then when the animation is done it shows the outline (proper the way I designed it).
    Running 10.2.2
    Thank you
    Roy
    Doug Metz
    replied 11 years ago
    3 Members · 3 Replies
  • Noah Kadner
    September 21, 2015 at 9:30 pm
    I’d send in a bug report if you can make it happen reliably and repeatedly.
    https://www.apple.com/feedback/finalcutpro.html
    Noah
    FCPWORKS – FCPX Workflow
    Call Box Training
  • Roy Mckenzie
    September 22, 2015 at 1:35 pm
    I probably won’t. I can’t believe I didn’t try this sooner but the work around is to take the opacity to zero on the face and leave it active. Shutting the face off causes the problem.
    Thank you
    Roy
  • Doug Metz
    September 22, 2015 at 3:30 pm
    [Roy McKenzie] “I probably won’t. I can’t believe I didn’t try this sooner but the work around is to take the opacity to zero on the face and leave it active. Shutting the face off causes the problem.”
    Still sounds like a bug… glad you got it sorted, though!
    Doug Metz
    Anode
