Activity Forums Maxon Cinema 4D Custom Text won’t fill, text see through, need to be solid
  • Adam Trachtenberg
    August 18, 2010 at 10:52 pm
    Looks like your trying to extrude a font that was designed with a 2D shadow effect, which isn’t going to work. Make the text spline editable, run Functions>Explode Segments, delete the outer/fake-shadow splines, and then extrude the remaining splines.
  • Ryan Ainge
    August 18, 2010 at 11:16 pm
    Thanks a lot Adam. I followed your instructions and it seems to be working so far. When I add an extrude to the text (see image) the text doesn’t extrude.
    Any ideas?
    https://yfrog.com/18capturecfj
    I tried grouping the edited text but that didn’t work. I’m guessing it has something to do with changing the text properties again?
  • Ryan Ainge
    August 18, 2010 at 11:18 pm
    Just figured it out. Had to delete the parent spline for it to connect with extrude.
    Thanks again!
