Activity Forums Adobe Illustrator custom text justification
  • custom text justification
    Posted by Todd Morgan on February 7, 2006 at 10:13 pm
    Hi there,
    Any thoughts on how to justify text along a custom curve, instead of using Quark? Is there a way to use paths and type to do this?
    Todd
    Todd Morgan
    Creative Director
    Freelance F/X Inc.
    Todd Morgan replied 20 years, 7 months ago 3 Members · 6 Replies
  • Richard Harrington
    February 8, 2006 at 2:36 am
    Both PS and Ai do this (newer versions)
    Look up text on path
    Richard M. Harrington, PMP
    Author: Photoshop CS for Nonlinear Editors
    Co-Author Final Cut Pro on the Spot, After Effects on the Spot, Broadcast Graphics on the Spot, and After Effects @ Work
    Check out the new DVD: Photoshop CS: Essentials for Digital Video from http://www.photoshopforvideo.com
    edit – produce – direct –
  • Todd Morgan
    February 8, 2006 at 3:01 pm
    I don’t want the text to follow a path. I want the text to justify along a path.
  • Kim Mackenzie
    February 8, 2006 at 5:39 pm
    Sounds like you want a Text Wrap.
    – click and drag with the type tool to make your text box
    – in the Paragraph palette, turn on Full Justification
    – select the path you want the text to justfiy to, go to Object > Text Wrap > Make Text Wrap
    – you’ll get a dialog box where you can set the width of the buffer around the object.
  • Todd Morgan
    February 8, 2006 at 8:06 pm
    In Photoshop CS???
  • Kim Mackenzie
    February 8, 2006 at 8:40 pm
    Assumed you were setting type in Illustrator, to which the above instructions apply.
    I don’t know of a way to do that in Photoshop.
  • Todd Morgan
    February 8, 2006 at 8:47 pm
    Thanks! Working with Illustrator CS and it is great! Didn’t realize I could open a Photoshop file and access my text. Cool!!! Thanks for your help!!!
