Activity › Forums › Apple Final Cut Pro › Custom speed change?
Posted by Esther Casas on May 2, 2013 at 9:20 pmHello everybody!
This might sound very stupid..I am new in FC X and can’t find the way to CUSTOM change the speed of a clip..i don’t want 2X or 4X…i want like a 15-20% faster…i only find the way to speed up from 2X and up (fast)and the slow options…is it possible custom speed up or down or i am stuck with this FC X?
With FC7 is so easy I can’t believe FC X does it difficult for you…
thanks to all!
Kirk Pitts replied 13 years ago 4 Members · 10 Replies -
John Davidson
May 2, 2013 at 9:39 pmPut the clip on a non-primary track. Select the clip and make it 2x or whatever. Whichever you choose doesn’t matter. Then, once the speed is changed, you’ll have a retiming bar at the top of it. Drag that to whatever length/speed you like.
It’s pretty dang easy :).
John Davidson | President / Creative Director | Magic Feather Inc.
John Davidson
May 2, 2013 at 9:40 pmOh, and when you’re done. Go back into the speed change menu arrow and under video quality, play with frame blending or optical flow. Sometimes those provide really awesome results.
Esther Casas
May 2, 2013 at 10:24 pmJohn!!! thank you so much! was going like crazy looking how to do it…yes, pretty easy! 🙂
one thing, i went to blending or optical flow and did not do anything to the clip…is it supposed to make a glow effect, is it obvious? i just clicked the option…
thanks!!!! -
Andy Neil
May 2, 2013 at 10:28 pmThere’s actually and even easier way to change a clip’s speed in FCPX. Just put the clip anywhere in your timeline. Select the clip and hit CMD+R (retime) on the keyboard. A little bar will appear over your clip and you can just grab it and make it longer or shorter to your taste.
Also, optical flow is just a much smoother interpolation when FCPX has to create new frames (for slo-mo’d clips) not sure it’ll do you much good on sped up clips.
Andy
https://www.timesavertutorials.com
John Davidson
May 2, 2013 at 11:44 pmOh, right. I was thinking you were slowing clips down. Think of Optical Flow as a smoothing option to help offset slow motion stuttering (like Twixtor in After Effects).
Kirk Pitts
May 3, 2013 at 5:01 pmAre there ease in or ease out controls for the speed? I can’t find them. I just installed FCPX yesterday so I am working through the changes from 7.
Kirk Pitts
May 3, 2013 at 7:41 pmFound an ease in ease out type method.
https://www.geniusdv.com/news_and_tutorials/2011/10/variable_speed_retiming_in_final_cut_pro_x.php
