Activity › Forums › Adobe Photoshop › Custom shapes along a path
  • Custom shapes along a path
    Posted by Tm Clark on September 1, 2010 at 12:52 pm
    Hi
    I need to be able to stroke a path with a custom shape eg DASHES around a SHAPE for which I can then edit the points.
    PS can stroke a path/selection… but it is not editable
    PS can stroke a shape with a pattern stroke but goes weird when you pull the points around
    PS can type text wingbats along a path then pull the points around (best bet but I may want different stroke images)
    but I want it to do as Illustrator would do… The art work on the stroke will always edit with the points….
    I can make a good custom shape with my art work, define that as one shape but I’d need more than one shape if the image aspect ratio changed too much)
    I can’t use AI for this though as I need to set up some actions on a folder ( all stills to have a artwork border)
    many many than Tim
    Scott Roberts replied 15 years, 10 months ago 2 Members · 1 Reply
