Activity Forums Adobe After Effects Expressions Custom script -> Adding null then setting parent
  • Custom script -> Adding null then setting parent
    Posted by Ralph Moreau on September 6, 2021 at 9:18 pm
    Hi everyone,
    I’m really a hobbyist programmer so bare with me if you can. I’m making a script that basically
    adds a null then selects the active layer as the parent. I’m nearly there but it’s just setting the parent . Here is the code:
    var comp = app.project.activeItem, props, n, p, idx;
    if (comp instanceof CompItem){
    props = comp.selectedProperties;
    var layNum = comp.selectedLayers[0].index; // number of designated chosesn layer
    var selLay = comp.layer(layNum); // actual layer object with the proper index.
    var inLay = comp.layer(layNum).inPoint;
    var outLay = comp.layer(layNum).outPoint;
    var inOutlay = Math.abs(inLay - outLay);
    var newNull = comp.layers.addNull([inOutlay]).moveBefore(selLay);
    comp.layer(layNum).setParentWithJump(layNum -1);
    Ralph Moreau replied 4 years, 11 months ago 2 Members · 2 Replies
  • Dan Ebberts
    September 6, 2021 at 10:30 pm
    I’m guessing this is close to what you’re looking for:
    var comp = app.project.activeItem;
    var selLay = comp.selectedLayers[0];
    var inOutlay = selLay.outPoint - selLay.inPoint;
    var newNull = comp.layers.addNull(inOutlay);
    newNull.moveBefore(selLay);
    newNull.startTime = selLay.inPoint;
    newNull.setParentWithJump(selLay);
  • Ralph Moreau
    September 7, 2021 at 8:22 pm
    Thank you Dan!!
