Activity › Forums › Apple Final Cut Pro › Custom output aspect ratio – 720×580 (NOT 4:3 or 16:9)
  • Custom output aspect ratio – 720×580 (NOT 4:3 or 16:9)
    Posted by Elena Solovieva on January 2, 2012 at 8:55 am
    I am trying to create a flash video measuring 720×580 pixels in FCP X. However, I can’t seem to figure out how to change the output video aspect ratio and how to edit for that size.
    If I use “Trim” or “Crop”, that doesn’t change aspect ratio of the final video.
    Can you please help? I will be hugely appreciative for a workflow, the more detailed the better (is my only option to use the Compressor?) Thank you so much!
    T. Payton replied 14 years, 8 months ago 3 Members · 2 Replies
  • Mark Morache
    January 3, 2012 at 8:46 am
    That’s a curious size. What’s it for?
    As for FCX, you cannot set up a project that size.
    You can in FCP7.
    You should have no problem setting up a preset in compressor to convert or even crop to create that final size.
    When you create a new project (sequence) you can specify a custom setting for PAL SD of 720×576. It’s 25fps. Is that what you’re trying to do?
    FCX. She tempts me, abuses me, beats me up, makes me feel worthless, then in the end she comes around, helps me get my work done, gives me hope and I can’t stop thinking about her.
    Mark Morache
    Avid/Xpri/FCP7/FCX
    Evening Magazine,Seattle, WA
    https://fcpx.wordpress.com
  • T. Payton
    January 10, 2012 at 12:14 am
    Turns out you can create custom resolution timelines in FCP X. Just posted this tutorial:
    https://library.creativecow.net/payton_t/FCPX_Custom-Resolution-Timelines/1
    T. Payton
    OneCreative, Albuquerque
