Activity Forums Maxon Cinema 4D Custom Metaball?
  • Custom Metaball?
    Posted by Julia K on January 29, 2009 at 3:01 pm
    Is it possible to have a modeled object other than a ball to behave under metaball effect? If not, is there another way of animating an identical object separating from its self in similar fashion to metaballs?
    Randy Johnson replied 17 years, 7 months ago 2 Members · 3 Replies
  • Randy Johnson
    January 29, 2009 at 3:28 pm
    The help menu has a very clear review of the metaball object.
    Yes you can use other objects in the meta but I have not had consistant results when doing so… perhaps some else can help you here.
    To be able to “animate away from itself” What kind of shape, a fluid motion ???
    /Randy
  • Julia K
    January 29, 2009 at 3:49 pm
    Yes, in fluid motion. It’s a fairly basic shape, looks like an elongated cell, but it has to keep its shape after it goes through the morph, I guess I could also morph? Since it has the same # of points? Although I’m not sure how to go about doing that…
  • Randy Johnson
    February 3, 2009 at 7:41 pm
    what kinda shape are you looking for? I think there are a few ways you could approach it but knowing the shape would certainly help…if it not too late.
    /randy
