Activity Forums AJA Video Systems Custom LUT and capture D21 log
  • Custom LUT and capture D21 log
    Posted by Mathieu Marano on May 26, 2009 at 7:15 pm
    Is the custom LUT function on the Kona 3 applies the LUT at the input or at the output?
    I got to capture D21 footage recorded on HDCAM SR but the footage is ArriLog. Can I use the custom LUT to do a log to lin conversion on capture?
    If not how can I do it?
    Mathieu Marano
    online editor – motion graphics – Post-prod director
    Directeur technique de post-production
    Le Bureau de post production
    Administrator of the Montreal Final Cut User Group
    http://www.finalcutmtl.org
    Ramona Howard replied 17 years, 4 months ago 2 Members · 3 Replies
  • Ramona Howard
    May 26, 2009 at 11:13 pm
    Mathieu,
    We can apply this in either place in Rave, but this may depend upon the application your using the Kona in. Some applications do not allow for work in extended range, therefore putting it on the the output will be moot, since the stream before it will be squashed (that would be bad).
    In Rave since we support full range DPX files, we prefer to apply this on the output so that the data is kept pure.
    Cheers,
    Ramona
    Play hard today, it may be raining tomorrow!
  • Mathieu Marano
    May 27, 2009 at 12:03 pm
    and what is Rave?
    Mathieu Marano
  • Ramona Howard
    May 27, 2009 at 7:54 pm
    https://www.spectsoft.com/index.html
    A disk drive recorder (that does more than the traditional DDR)
    * We use the AJA boards in our solution and have written our own driver for them.
    Cheers,
    Ramona
