Activity Forums Adobe InDesign Custom Image Frames
  • Custom Image Frames
    Posted by Russell Cory on May 5, 2006 at 3:11 pm
    Hello, I am curious if there is a way to convert IllustratorCS paths into custom image frames in InDesignCS. I am trying to avoid having to re-draw shapes with the InDesign pen tool..
    Erica Gamet replied 20 years, 2 months ago 3 Members · 3 Replies
  • Alex Salerno
    May 9, 2006 at 7:59 pm
    Copy path in Illustrator. Paste into InDesign document. Go under the Object menu>Content and select either Graphic or Text.
  • Russell Cory
    May 9, 2006 at 8:39 pm
    Thank you, I will use it!
  • Erica Gamet
    June 21, 2006 at 3:06 am
    Remember: to copy from Illustrator and paste into InDesign, you must have your Illustrator prefs set to use AICB (in the File Handling & Clipboard pref) and also choose “preserve paths” for this to work. Keep in mind, this will not be a linked file once placed in InD, so any updates to the AI file would have to be re-copied and re-pasted.
