Activity Forums Compression Techniques Custom Frame size with Mpeg 2 compression?
  • Custom Frame size with Mpeg 2 compression?
    Posted by Keith Wells on September 13, 2013 at 6:59 pm
    Does anyone know how to convert a 10bit Uncompressed Mov with the Custom frame size of 1344 x 384 to an MPG2. Its to be broadcast on a large LED Screen in China at that resolution. They are insisting on that frame size and that it be an MPG2. I know that the MPG2 algorithm doesn’t like custom sizes but How can you get a custom frame size?
    Ivan Myles replied 12 years, 11 months ago 2 Members · 3 Replies
  • Ivan Myles
    September 13, 2013 at 8:36 pm
    Adobe Media Encoder supports custom dimensions for MPEG-2. Be sure to set Level to High. That should work with 1344×384.
    MPEG-2 Profiles & Levels Wiki
  • Keith Wells
    September 14, 2013 at 7:52 pm
    Thank you so much. Using Adobe Media Encoder from CS 5 worked really well after installing the updates. I got what I needed in the first encoding. I was using compressor and ffmpeg among other, nothing was doing it except a website which offered essentially zero control. I appreciate your comment.
    thanks
  • Ivan Myles
    September 15, 2013 at 4:26 am
    Happy to help. Glad it worked for you.
