Activity Forums Apple Final Cut Pro Legacy Custom Frame Size / Aspect Ratio / HD Footage
  • Custom Frame Size / Aspect Ratio / HD Footage
    Posted by James Withers on August 28, 2008 at 3:43 pm
    I’m working on an edit of HD footage. I’m been editing it at the moment all fine, but the final render is going to be projected at 960×1080 (portrait). Is there a way to adjust my frame size so I can see how my footage will look when cropped?
    When I changed the frame size to 960×1080 (custom) in the sequence settings, I then have to pre rendering every shot, so every time I make a change or adjust a clip I have to pre render it.
    I was just wondering if this can be worked around.
    Thank you all in advance.
    James Withers replied 18 years ago 1 Member · 0 Replies
  • 0 Replies
